My website URL is:
What I’m seeing is:
This either means that the username and password information in your wp-config.php
file is incorrect or we can’t contact the database server at sql105.epizy.com
. This could mean your host’s database server is down.
- Are you sure you have the correct username and password? YES
- Are you sure that you have typed the correct hostname? YES
- Are you sure that the database server is running? NO
Additional information:
I upload correctely a new wordpress installation. Configured correctly the database. But the installation failles because it seems the database server sql105.epizy.com is not running.
