Ssl certificate for mysite.rf.gd
Hi,
I’ve been trying to figure out how to get SSL cerficates for my site here on Infinityfree (michelpetrelli.rf.gd). I have pravato to use the SSL TLS panel but does not appear the certificate in the third box at the bottom. I don’t know how to do that. Can you help me? I thought it was easier.
Hi and welcome to the forum
It would be good to read all in HTTPS and SSL section here
Thanl you! Is there a possibility to install certificates obtained free of charge? Can you address me?
The quickest and easiest way also with additional benefits
Is that you use CloudFlare and add your domain there
But right now you don’t own a domain but a free subdomain (rf.gd)
and CF only works if you are a domain owner
How to get free domain ? here Freenom - A Name for Everyone
Then add your domain here
for example as addon domain
Wait for DNS propagation
Upload files to the corresponding htdocs folder
And when everything works then add the domain to CF
and follow there further instructions regarding NS modifications
Wait again for DNS propagation
Pay attention that all your code is HTTPS Instead of HTTP (If you have such calls - absolute PATH)
When it works then you turn on CF - Crypto section = SSL Full
(And for all other options for Cloudflare read help there inside dashboard)
Cloudflare installs an SSL certificate on your website automatically, but takes up to 24 hours to do so
With all of the above - If you use WordPress
properly configured WordPress installation doesn’t need any third party plugins to use HTTPS URLs.
after a while change wordpress to use HTTPS
thank you, it’s very clare.
