[Try running Windows Network Diagnostics](javascript:diagnoseErrors()).
ERR_SSL_PROTOCOL_ERROR
I created an SSL certificate from the client area and give the private key and certificate in the SSL/TLS section in the control panel(cPanel). and I set the cname record everything is ok.
I had checked your site!
For me its showing properly without any error except SSL!
So try to check in private tab or incognito!
And clear cache and try!
If u r not ready to share sceenshot na!
U should review ur coding yourself in theme files!
As u say styling problem occurs then we cant solve it without seeing and knowing what is the exact output you need!
no sir there is not a problem. but when i first time go to my website then the styling not works perfectly, but if I refresh the page the styling works perfectly. so i think this the problem with hosting provider
@somendas, I’m not sure that you mean by icons are not showing on mobile, because it works fine on my phone. It is probably a caching issue, and you can confirm that by using a different mobile browser.
As for SSL, both you and @HELPINDIA should find similar posts in the form, like the one below that says SSL is having issues.
Thanks
I have the same problem. I have done all the steps as described in the guides to get and install a Free SSL certificate but once I got the certificate and installed it, it doesn’t work. My domain is federicaeluca.ch
I read that someone says you can only wait. Do the administrators of infinity free know about this problem? Thank you very much for everything you do for the community!
