Ssl problem
hello , i installed wordpress with automatic setup and i add ssl but my web site www.mapub.xyz not have SSL , and page of admin i can not find it !!! can you halp me plz
Hi tarikvps24,
For SSL and HTTPS related, you may install a SSL certificate in Client Area, and from there request a certificate > setup DNS records. Once that’s ready and after propagation, you will have the option automatically install it.
Just in case:
Cheers!
First of all you need to install an SSL certificate to transform your WordPress website from HTTP to HTTPS. I have mentioned a few steps that can be helpful for you.
  1. Open the WordPress admin panel and find Settings.
  2. Click on Settings and navigate to the “General” option in the side menu.
  3. In the dialog box, you will see different columns. Check that the first two boxes, WordPress Address (URL) and Site Address (URL), show https://
I hope this helps you well, if not then I personally refer to this https://cheapsslweb.com/resources/redirect-wordpress-website-url-from-http-to-https to get better understanding.
my store is www.mapub.xyz where to go to dashboard !!! (https://mapub.xyz/wp-admin/) !!!
Like @chiucs123 already said: this error is because your website is configured to use HTTPS URLs, but not SSL certificate is installed. The best way to fix this is to just install an SSL certificate:
We provide all the tools you need to do so, but you still need to actually do it yourself.
