I want to create sub domains for sub domains aka sub-sub-domains and so on. For example sub.sub.domain.com or even [sub.sub.sub.domain.com], how long you want. I think this would be cool!
(post withdrawn by author, will be automatically deleted in 24 hours unless flagged)
Actually it is possible in cPanel but not on vPanel. Don’t know the exact reason.
You are weird.
Mostly people want a short URL for their domain.
Because more short, more higher its price. & more easy to be remembered/typed.
Technically, you can do that. All you need is Cloudflare.
You add an A Record to point to another domain, for example:
Host | Points To |
sub2.sub1.example.com | IP of another website |
I like long, say for account login, instead of hn.fyi/account/login, i would use http://login.eu.hn.fyi
May this helps:
And subdomain of subdomain will challenge you to subdomain rate limitings, ssl limits, and etc which you need to encounter, though.
