So my subdomain photography.rjamkatel.com will not work; and my email will not recieve messages and I do not know why, can someone help?
also I want to note I am using G-suite and all the MX-Records in cPanel are correct.
Due to the way the Cloudflare integration in our panel works, it breaks all other DNS records. That means you cannot have subdomains or MX records while using our Cloudflare integration.
Please disable the control panel Cloudflare integration if you also want to receive email or use subdomains.
