Website URL
development.trgop.gq
It says that “domain ip address not found”
I created an “A” record and pointed it t the weebsites ip, but still not working.
In CPanel, it shows my subdomain, but in the home page (where ftp, cpanel, and mysql details are given) it doesn’t shows my subdomain
What is the website IP? If it is listed in the topic below, it will be unreachable because those IPs are down.
Multiple IP’s Down
First reported 2/1/2022 at 7:45 GST, multiple IP address have gone down, and are unreachable.
Which components are affected by this issue
Websites hosted on the following IP’s are affected. You can view what IP your website is on in the client area.
185.27.134.148
185.27.134.147
185.27.134.146
185.27.134.145
185.27.134.107
185.27.134.106
185.27.134.105
185.27.134.104
What issues may you see
Endless loading
“Site cannot be reached” message
“The connection has time…
@wackyblackie
My website ip isnt listed there
But still its not working
KangJL
February 2, 2022, 5:53am
#4
Of course it’s not working
Correct your error
ohh, so i have to remove cloudflare nameservers?
KangJL
February 2, 2022, 6:25am
#6
Are you using CF? If you are not using, then
I m using Cloudfalre and infinityFree both
Cant i use like that?
KangJL
February 2, 2022, 6:28am
#8
No, mixing nameserver will cause your domain/subdomain not to work
k, lemme remove and import and try
Can i add TXT records?
If yes, then how?
k tysm
I just wanna ask a last question
After setting up like this, theres no need of infinityFree nameservers ryt?
KangJL
February 2, 2022, 6:40am
#14
Yup, if you follow the guide correctly
yup it is
Thank You o much for your help
system
Closed
February 9, 2022, 6:56am
#17
