shtayga.ga
When I started using my website (which is on a custom subdomain), instead of opening my index.php, it sent me a 404 error.
shtayga.ga
This is the main site with index.html
You need to click “влез в играта” or enter app.shtayga.ga
Do you see a pattern?
It looks like app.shtayga.ga redirects to “https://app.shtayga.ga/auth/login?q=/”, witch redirects to “https://app.shtayga.ga/error/404.php/” witch redirects to “https://app.shtayga.ga/auth/login?q=/error/404.php/” witch redirects back to “https://app.shtayga.ga/error/404.php/” creating an endless loop.
Because something in php messed up…
Error 404 is because the server thinks file login.php doesn’t exist…
In my code: if I’m trying to open 404.php, i need to login (that part is my mistake)…
If i didn’t refer to 404.php it will stop and say: this page didn’t exist.
I just messed up the code
