I add domain in my free account then i create sub domain on my .co.in domain but i can’t access my subdomain.
what’s your both domain url and its subdomain?
are you sure your domain points to ns1.epizy.com and ns2.epizy.com nameservers?
if yes. you should wait for while to your subdomain starts working
How to check it?
maybe?
https://infinityfree.net/support/how-to-use-infinityfree-nameservers/
it depends on the site which you’ve get your domain from it
Your domain is pointing to Cloudflare nameservers. On the DNS page, you should put a CNAME record with as name ganesh
and as value @
for the ganesh
subdomain to work.
Thank You for reply
Then both domain work separately?
Both domains will work with the contents you put in the respective htdocs folder. If you created the subdomain ganesh
for your domain the respective htdocs folder for it is ganesh.send-wish.co.in/htdocs/
, while for your domain is htdocs
I add CName record but still same error display.
Did you change the changes from the Cloudflare dashboard’s DNS page or from the “CNAME Records” section of the Control Panel? If that’s the latter, please do that on the Cloudflare dashboard’s DNS page, and wait for DNS propagation.
Yes, I make change from Cloudflare.
Sorry, Your Solution is working after change it took some time. After sometime i refresh it’s working
Thank You.
