Can confirm that I can still not access it with either the web or the local client option.
Same here. I cannot connect to FTP. getting error message 502 bad gateway
Same ca’t connect on my ftp for a few hours, it say:
Error: | Could not connect to server |
Status: | Waiting to retry… |
Status: | Resolving address of ftpupload.net |
Status: | Connecting to 185.27.134.11:21… |
Error: | Connection timed out after 20 seconds of inactivity |
I need ftp be working ASAP thanks.
Same here, was able to use FTP early today but since then can’t log in
It’s not just InfinityFree. I have another site hosted elsewhere (but also based off of iFastNet) and I am having the same issue.
On that other host I am unable to connect through CPANEL or FileZilla.
Same with me. Before this i’m using another web hosting i able to connect using Filezilla. Please fix !
Unable to connect as well, using both Filezilla and MonstaFTP and both are unable to connect to the FTP.
Kindly suggest alternative solutions please?
same here, need solution ASAP.
i have this issue too
Both FileZilla and File Manager are unable to connect
Please Fix This issue as soon as possible
nope, both cannot connect to ftp
Cant access FTP on both cpanel and filezilla. No other way to update the files.
Where did the Admin go? Can you give us an update regarding this issue? Thanks!
nobody cares
Same here won’t connect on Filezilla or Cpanel .
Ill jump on this too, yeah i cannot connect either
same here, I’ve registered account within last 12 hours and can’t connect neither using cpanel nor using filezilla
Please fix the issue, it is there since yesterday and it is hampering my work
Thanks in advance.
