epiz_26265291 → http://brickplanetrevival.rf.gd/
Failed to connect to MySQL: Access denied for user ‘epiz_26265291’@‘192.168.0.43’ (using password: YES)
Please tell me how to fix this!
Have you read this already senpai?
How would I fix it tho?
It says nothing about fixing it
Have you read the support KB link above? I mean all of the content?
Yes
Please read it, there was an option or step by step on it on how to fix your problem
From KB link above:
Access denied for user[¶]
You can see an error message which looks like
Access denied for user 'epiz_12345678'@'192.168.0.*' (using password: YES)
Follow it in order to fix your problem by your own.
Make sure you are using correct credentials
