After Uploading the Php script (linkshield v4 ) website Is down… Whats the reason?
Please fill out the template.
https://linkzshield.gq here i installed V3 degraded frm V4
And on https://textdump.cf here i installed V4
Plz chexk where i am wrong
Can you please send the link to the script?
File: Link Shield v3.zip
https://anonfiles.com/r4m1z5O1x5
File: ShieldScript.zip - V4
Here is your download
https://anonfiles.com/F9m2z3O3xf
Possible… Before Adding the script… Domain showed All the index of. Files… After adding… The script. The error occurred… After removing the script… Still error remains the same.
Admin
March 15, 2022, 3:11pm
8
Linkzshield:
website Is down
What error? What do you see exactly?
On https://textdump.cf/ , I currently see a redirect error. I also see you’re using Cloudflare. This is usually caused by using Cloudflare Flexible SSL. Instead, you should request and install a self signed certificate on your hosting account, and then set Cloudlfare to “Full” SSL mode.
These are the two errors.
Don’t really sure about dns Configuration error.
Suggest something to make site online please
Install SSL, follow this guide:
If you’re using free hosting with your own domain or a subdomain, you’ll want to make your website work over HTTPS (SSL). Fortunately, InfinityFree provides all the tools you need to make it so. If you like videos better then text guides, scroll on down to the bottom of this guide.
This guide uses the control panel functions and the Free SSL Certificates tool provided by InfinityFree to get SSL up and running on your site.
Step 1: Set up the domain on your hosting account
The first thing to d…
Admin
March 15, 2022, 7:09pm
11
I already did. Please read my previous post.
You need to make your Website secure from installing SSL certificate
system
Closed
March 23, 2022, 10:35am
13
