Onion is a Coder, and Web/Discord bot Developer. Order services like Discord Bots/Websites from me! I code in Node.js, HTML, CSS, JavaScript
In my registrar, it says that my domain is active. M using Cloudflare in which there’s an A record setuped correctly as my website ip. But, when i go to my domain, or any subdomain of it, it says either that it’s DNS problem, or it says that check for typo in the domain. Everyhing is correct, still everything is down.
Pls help me
KangJL
June 26, 2022, 12:54pm
#2
Did you follow this guide?
Hello,
I will show you how to easily set up Cloudflare, Edit Records, and Troubleshoot with images!
PLEASE READ BEFORE STARTING!!!
Cloudflare cannot be used on free subdomains from InfinityFree
You can use Cloudflare on Custom Domains (yoursite.com ) and with Custom Sub-Domains (subdomain.yoursite.com )
A video tutorial can be found at the end of this guide, should you get stuck.
You must connect your domain to your InfinityFree account first. Read more here .
------- Set-Up Cloudflare -----…
It was working afew days before, but today i got to know that its down.
A few days before also, it was working on cloudflare setup.
Its been a much months since i shifted to cloudflare, and everyting was fine until today
Working for me
What do you mean by “down”? What error are you getting?
Its been many months since i started using this service.
My domain has been added here since i created account herr
I think you are having the same issue as this person:
Website URL : www.dhawansolanki.cf
This site can’t be reached
DNS address could not be found. Diagnosing the problem.
DNS_PROBE_POSSIBLE
I found out my website is not working from last few hours… Couldn’t load a single page shows DNS probe error.
Please Help !
Thankyou.
I would do this:
Then the issue is with FreeNom. As your Nameservers are not fully propagated. I would try waiting a few days, and if the error still occurs, check back in.
EDIT: You could also try using a different network/device
system
Closed
July 3, 2022, 1:26pm
#9
