epizy.com is online for me, but the WHOIS says right, it will expire today… But it may be auto-renewed by the owner of the domain registration. So we don’t need to worry about it.
So I should just wait?
My DNS records are the following:
CNAME: @ to my main domain
CNAME: www to @
MX: @ to mx.epizy.com
They are right, but you also need to disable Cloudflare in your Control Panel for your domain.
I already did it when I fixed it last time
Same for me.
Website is down, even cpanel.epizy.com is down with msg DNS_PROBE_FINISHED_NXDOMAIN
Please advice not recieving email as well.
Did you read the article I posted recently?
Yes thank you this resolved the website issue.
but still not recieving emails.
Please advice regarding the Email correction procedure.
thank you
Correct the MX record’s value to mx.byetcluster.com
from mx.epizy.com
from the Control Panel accessible from https://cpanel.freecluster.eu with the credentials of your hosting account and wait some time for DNS propagation.
The main domains are tied to a particular domain name, so you can’t just change the CNAME records to byet.org or byetcluster.org. But you can find out the real IP address and use that in your DNS settings. Since the main domain itself, the usual instructions don’t work, but there are workarounds.
If you use this interface, you can enter your domain name in the top left box, click Dig and get your IP address from the output at the bottom of the page: https://digwebinterface.com/?hostnames=rgxpadqa.epizy.com&type=&useresolver=8.8.4.4&ns=self&nameservers=ns1.byet.org
Using the IP address (which looks like 185.27.134.XXX), you can remove the CNAME
record from your DNS and add an A
record, which should have that IP address as value.
So i should remove the CNAME that goes from the root to the main domain and make a new record with the root as name and goes to the ip adress I got, right?
Yes, you should make a new A
record.
Ok, I just changed it. I will wait some hours so that the changes can be done and published.
For me ftpupload.net works fine. You can replace it with 185.27.134.11 if you have problems with that, and use the “Plain FTP” connection method while on FileZilla’s Sites Manager.
Yes, now you can.
