My website URL is:
What I’m seeing is: I read all the benefit of turning on cloudflare, are there any hidden cost or embeded AD? what does cloudflare used for ?Any cost later on ?
I’m using this software:
Additional information:
My website URL is:
Cloudflare doesn’t have any hidden cost or embedded ads inside the free plan.
Cloudflare is used to add a global CDN (Content Delivery Network) for your website, making it sure that visitors can access your website faster than ever. It also has some good features, like SSL/TLS support, DDoS attack prevention page, HTTP/2, 0-RTT and coming soon also HTTP/3 with QUIC.
If you want to use some other features of Cloudflare, since it hasn’t them all on free plan, you can also pay for a bigger plan. If you don’t want to use them, then you can still stay on free plan and not pay any cost for that.
Thank you for the answer …Sounds very interesting.
Cloudflair is speed booster with free SSL certificate,he gives you CDN speed.
There is no hidden cost to cloudflare, the free plan is %100 free.
Cloudflair used for speeding up site speed as well as for security.
Got it .Appreciate it.
