epiz_27066297
website: http://daestore.infinityfreeapp.com
I try to install the woo-commerce plugin on my website for practice but it is not installed. I try it again and again but not work. help me, please.
epiz_27066297
Do you have a screenshot?
You need SSL cert for ur website to work
@dilshadahmad Try updating through FTP.
@KangJL Umm,that is a Really Simple SSL plugin error and not a Woocomerce plugin error.But still having that plugin is waste coz you didn’t install an SSL
Sorry, my bad…
I try to activate SSL using a really simple SSL plugin. You see update failed to woo-commerce plugin install.
I believe u need to install SSL cert first before using a really simple SSL plugin.
Woo-commerce plugin need installation via ftp.
