Perhaps this link will help. 7 Reasons Why Your WordPress Plugins or Themes Won’t Install
I’m sorry for what I posted. It wasn’t really helpful.
No. None of the suggestions in the article are related, the errors I’m getting are different.
Plugin error:
Installation failed: There has been a critical error on your website. Please check your site admin email inbox for instructions.Learn more about debugging in WordPress
Theme error:
Installing Theme from uploaded file: Avada 6.1.2.zip
Unpacking the package…
Installing the theme…
Same type of error, I’m not getting an email to clarify the error so I’m waiting for the admin. 5 days and counting
You should try to install plugins and themes that have a big number of files or don’t install by using the WordPress dashboard via FTP. Here are the instructions for installing a plugin via FTP and installing a theme via FTP.
Installing larger plugins and themes can easily fail, because of file size limits and script execution time limits. It’s a known and fairly common issue and not really the desired experience for anyone. But the only “fix” I can think of is to increase the limits for free hosting, which is not something we can do just like that.
Fortunately, there is a good workaround. LIke @Ergastolator1 said, you can circumvent these issues by installing the theme manually through FTP.
Thanks Ergastolator1, installing it via FTP does work. It’s a bit unfortunate that there’s no other way, but it’s better than nothing
