Wordpress Connection timed out
Hello everyone:
I’m Using WordPress with my own domain. I’ve enabled debug mod. and these error messages showed up. Can anyone help, please?
Warning : mysqli_real_connect(): (HY000/2002): Connection timed out in /home/vol18_2/epizy.com/epiz_28862612/htdocs/wp-includes/wp-db.php on line 1653
Deprecated : mysql_connect(): The mysql extension is deprecated and will be removed in the future: use mysqli or PDO instead in /home/vol18_2/epizy.com/epiz_28862612/htdocs/wp-includes/wp-db.php on line 1685
Warning : mysql_connect(): Connection timed out in /home/vol18_2/epizy.com/epiz_28862612/htdocs/wp-includes/wp-db.php on line 1685
This either means that the username and password information in your wp-config.php file is incorrect or we can’t contact the database server at sql308.byetcluster.com. This could mean your host’s database server is down.
  • Are you sure you have the correct username and password?
  • Are you sure you have typed the correct hostname?
  • Are you sure the database server is running?
If you’re unsure what these terms mean you should probably contact your host. If you still need help you can always visit the WordPress Support Forums.
Thank you
Hey there,
There are currently some ongoing DB errors, so you will need to be patient white iFastNet fixes the issue.
Thanks
Yes. I’m reading pinned post on the forum. new to this
This one is not pinned yet, so no worries :slight_smile:
