hi, I tried to install wordpress with the one-click installation script provided in the control panel, but got below error message:
The following errors were found :
The MySQL Connection could not be established.
any suggestion to solve the problem? thanks in advance.
The MySQL Connection could not be established.![Captura%20de%20tela%20de%202019-05-08%2018-30-19|666x500](upload://nYMpbCNCgsbFa0gX748d7MfCsJx.png)
? I didn’t say ‘established’ at all, where did you get the screenshot?
this is the first app I tried to install, so there should be no any other database now.
If you are getting Database Connectivity Issues, Please check
PhpMyAdmin from your cPanel and check for the correct database and seek tables something named inside as wp_ etc.
If there is no database, that must be a corrupted wordpress installation. Please make desired backup and reinstall wordpress from cPanel - Softaculous.
I’m wondering if each line of this error ’ * The MySQL Connection could not be established.’ refers to every single account. I have two accounts on my Infinity Free and I get two messages.
If that would be the case then the problem would (most likely, I think…) be between the script and the hosting account.
Maybe this can help? I’ll also add that I tried installing the Wordpress script with all four options from the ‘choose protocol’ dropdown list. Plus I do not have a SSL certificate for my website
