Can somebody help me.
I start a blog,and I installed wp.
I want to change the favicon.ico but I can’t find the it.I also wonder where was the robots.txt,sitemap.xml.
Thanks.
Thanks.
By the way, do you know where was the sitemap and tobots.txt stored?
Please look into the theme that you are using
Did you create it in the first place?
The files favicon.ico, robots.txt and sitemap.xml are all files typically found in the htdocs
folder of the particular site. However, none of these files are created by default. If you want to have these files, you can just create them yourself.
Thanks.
