The following error occurred while connecting to the database:
No such file or directory
This indicates that your configuration information is not correct. Please check the values you have entered. If you are unsure what values are correct or how to proceed, please contact your host for help. These values are specific to your server.
Trying to set up my XenForo website and get that error when connecting to the MYSQL. I read somewhere else if you change your account password then it may mess things up, and I did that after it did not work the first time. Any help is appreciated!
Usually with applications like these… there should me a config file in the file manager… Take a backup of this file and then try adding the credentials directly into the config file maybe…
Also, this maybe just me, but are you sure epiz_27762025’@‘192.168.2.186 is your MySQL. Cause for me and all, it’s 185.27.134.10 and that one sounds like a localhost IP Address
I believe you need to read the article properly. There is one and only one reason why you may see a “No such file or directory” error when trying to establish a database connection: you are using localhost as your database hostname. This is 100.00000% guaranteed to be the only possible explanation.
