I heard that the IPs also have geographical data (what number is assigned varies somewhat correlated to area), and I’ve also heard that they hold samples in the database of IP addresses from various places, and if the former is somewhat true then the latter will be accurate enough.
Also, a quick google search tells me that there are numerous ways, so it may or may not use your method or the one I know.
The train probably does not have AI, but it is possible that even as such a normal form of “life” it evolved and saw the danger of AI and ran over that robot to protect other fellow trains or is simply jealous.
I’m actually the owner and the admin, and the admin is actually the moderator, the moderators are bots
and so on… That’s how we shuffled the cards to confuse you all.
I didn’t list everything because there is no need - the point is to show the basic principle
It all boils down to which is the older chicken or the egg
Only when someone reviewed from outside some IPs, he noticed a pattern and realized that those IPs that start with 123.456.X. belong to a certain region,
ISPs generally won’t say publicly how they arranged the network from the inside.
Most copper/optical lines have the first three segments of IP
that belong to a certain region because it was easier to organize traffic and provide support (it is known immediately in which region the problem is), just like when you assign some IPs on the local network and you know that 192.168.1.2-10 belong to your devices and those from e.g. .11-20 remain random devices connected to the router.
But for example, 3,4,5G (mobile data), which does not have underground lines, at least for me, does not have that division by region, but always shows the capital (headquarters of the company), etc.
It’s a shame we could never stop you from obtaining our time travelling technology.
In any case, I couldn’t find this post anywhere, so DMs? Sneaky, aren’t we @wackyblackie?
I won’t tell you if you’ve changed the course of events. You’ll find that out yourself, soon.
Denying does not look good, unless… you truly don’t know? I didn’t count for this outcome.
Forget I said anything… or don’t. Events are set in motion anyway.
In any case, I’ll join the quote war even if late:
The International Paranormal Event Monitoring Agency has identified a class 2 type extinction threat for the entirety of the area covering Earth. A class 2 type extinction threat is one that has the potential to destroy the entire human population. Dangers range from severe to fatal. IPEMA has identified numerous threats across the globe, including:
Anomalous effects from the moonlight. At night, close any windows or board them up. If that is not possible then seek shelter in an area of your house away from direct line of sight from the windows.
Unidentified creatures of an unknown origin have been spotted at night. Lock all doors and close all windows. If possible, close the shutters and/or board your windows. If a creature is nearby then do not look them in the eye.
Spacetime distortions have sporadically manifested at various different places. It is advised to refrain from entering these areas. If you are in an area that has received spacetime distortion then evacuate immediately.
Black wells have opened up in certain areas. Maintain distance from them and do not approach them under any circumstances.
Various massive creatures have been spotted to be floating in the upper atmosphere. If one approaches your region then seek shelter in a basement or the lowest and most stable area in your house. Do not be near windows or any exterior walls.
Eel-like creatures have been observed moving around urban areas. Physical human contact with them causes immediate disappearance of the individual. Keep your distance from them and avoid them at all costs.
IPEMA will issue additional alerts as new crucial information is presented and as new threats arise.
