Dear @Admin,
Still Problem persists, and also now my site is loading as http instead https.
Now what can I do?
Dear @Admin,
Now what can I do?
@DhananjayS said:
Dear @Admin,Still Problem persists, and also now my site is loading as http instead https.
Now what can I do?
Did you also delete the redirect page rule I told you to delete before? If not, you need to do that now, because that page rule is responsible for your website not working.
@DhananjayS said:
Dear @Admin, I already deleted it.
Hmm, odd, Cloudflare is still sending the redirects back.
Could you please check what the SSL Mode is in Cloudflare? If itâs âFlexibleâ now, try setting it to âFullâ.
Dear @Admin,
According to your Suggestion, Iâve turned my SSL to Full not Full (Strict),
And also; please tell me which setting Iâld turn on,
because my site is default http not https,
Please tell ASAP!
Well, it looks like the SSL mode was the problem, because I can see the wp-admin login page now. Can you please confirm it works for your as well.
As for the other settings:
