This shd help…
True, yesterday after many attempts I finally managed to install the certificate, but today it no longer appears but on the panel it shows me that the certificate is installed, but it has a detail, in wordpress it appears as no certificate installed, that since yesterday, even though it was with the padlock. Does it have something related?
Another thing is that before getting the certificate I installed 2 plugins on the WP to try it out. SSL Zen and Really Simple SSL. But it was not for them that I got the certificate. Are any of them causing conflict?
Ah! I think @KangJL solved it!
You site is using HTTPS but you are only viewing the http version.
If you go to https://guiadopodcast.ga/ it works, but if you go to http://guiadopodcast.ga/ it does not (Because the second link does not use HTTPS) If you follow the guide @KangJL posted, you can force all of your sites visitors to the second link if they go to the first link.
Good Luck!
FRIENDS, EXCUSE THE LACK OF EXPERIENCE. I CANNOT TRANSFER FROM HTTP TO HTTPS. I SAW THE TUTORIAL AND I UNDERSTAND THAT I SHOULD ADD CODES TO .HTACCES, BUT IN MY “HTDOCS” FOLDER I HAVE ALSO SEEN SOME VIDEOS THE ONLY DOCUMENT I HAVE HTACCES IS THE BELOW THAT IS WITH SOME ERRORS. I TRY TO ADD THE AI CODE, BUT THE FOLLOWING MESSAGE “ERROR DURING FTP UPLOAD PERMISSION DENIED IN” HTACCES “. I HAVE ALREADY TRIED BY THE CLOUDFLARE ALSO ENABLED THE” ALWAYS USE HTTPS “AND ALSO THE” RESTRICTED "HAS MORE RESET. DIFFERENCE.
MY HTACCES APPEARS LIKE THIS.
What does the .htacces file say at the top?
“DO NOT EDIT”
So don’t edit that file!
You need to create a new .htaccess file in the /htdocs directory and put the .htaccess code there. As for uploading, make sure you use FileZilla
unfortunately it is not working. I copied and pasted it straight from the site, it didn’t work. I played in the notepad, it didn’t work. The filezilla is giving error in my account even putting host, password, port everything correctly. I just need to force http to become https but it’s very difficult.
Sorry friend, i don’t understand. How do i do it??
Hello friend, I was finally able to switch to https after I changed the server names in the domain registration to the cloudflare server names, but after that the following problem started to appear. I can’t edit the site with elementor anymore. It says “The optional imagick module, is not installed or has been disabled”. I believe that’s why I can’t access Elementor. Can you help me? in the Mozilla Browser only when I access the admin area it keeps showing up like this …
Parts of this page are not secure (such as images)
That’s what it says in the image above.
Install Really Simple SSL plugin?
Please make sure that both Cloudflare and WordPress are configured correctly.
