My website URL is: matbout.com
What I’m seeing is: Can’t reach the website (DNS_PROBE_FINISHED_NXDOMAIN).
I’m using this software: Google Chrome
can you please change your domain name servers to ns1.byet.org, ns2.byet.org and etc? after you’ll wait for 72 hours.
edit: thank you E01
Correction: the nameservers are not ns1.byet.com and ns2.byet.com, but ns1.byet.org, ns2.byet.org, ns3.byet.org, ns4.byet.org and ns5.byet.org!
For the rest, I’ll just leave you alone.
i was misunderstand. thank you
I have the exact same problem.
Have the domain name servers changed?
i use ns1.epizy.com and ns2.epizy.com and checked that they haven’t changed since the problem appeared
So did changing the nameservers solve the problem for you?
The nameservers haven’t changed, but it’s possible that your nameservers have.
If you want someone to check, could you at least say which domain is yours?
Hello,
First i checked the nameservers on namecheap and they were ns1.epizy. com and ns2.
Then i was reading the forum and saw that byet.org is equal to ns epizy . I set the nameservers to ns1.byet and ns2.
Still no change , maybe its needs 24hours more.
I just checked your domain and it seems to be working fine now. The DNS settings of your domain look OK too. I do get an SSL warning now because you’re redirecting to HTTPS but don’t have a valid SSL certificate installed.
Hello
yes indeed. I checked a few hours ago and it was on.
Changing the nameservers to byet.org seems to have solve the problem.
I have not activated the ssl yet.
Thank you
2 posts were split to a new topic: I get the - " Lets Make Something Awesome page’ what should I do next
