So what should i do now?
Well there is nothing you can do. You and everyone else just have to wait for iFastNet to renew the certificate.
EDIT: It seams the panel is back online!
Thank you !
username: epiz_28647637
website: a11i.eu
ERR_SSL_PROTOCOL_ERROR
I am using free hosting plan and have a problem setting up the SSL/TLS.
I generated a new “Let’s encrypt” certificate using the https://app.infinityfree.net/ssls tool and got a private key and certificate. Successfuly uploaded the key and the certificate in the cpanel. However the when I tried to open my domain https://www.a11i.eu with Chrome I got the following error: ERR_SSL_PROTOCOL_ERROR
I tried to diagnose the problem with openssl
openssl s_client -connect a11i.eu:443
CONNECTED(00000003)
139810635650304:error:14094438:SSL routines:ssl3_read_bytes:tlsv1 alert internal error:../ssl/record/rec_layer_s3.c:1399:SSL alert number 80
no peer certificate available
No client certificate CA names sent
SSL handshake has read 7 bytes and written 176 bytes
Verification: OK
New, (NONE), Cipher is (NONE)
Secure Renegotiation IS NOT supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
Protocol : TLSv1.2
Cipher : 0000
Session-ID:
Session-ID-ctx:
Master-Key:
PSK identity: None
PSK identity hint: None
SRP username: None
Start Time: 1621376327
Timeout : 7200 (sec)
Verify return code: 0 (ok)
Extended master secret: no
I verified that the private key is 2048 bits (with openssl rsa -in private.key --text -noout
I tested the certificate inside local nginx and hardcoded ip address of a11i.eu in /etc/hosts, and Chrome recognize the certificate as valid, so at this point I think the private key and the certificate key are generated correctly.
What could be the problem? Is there any additional step that I need to do in order to configure HTTPS?
Thanks
Hello, please see the other topics already created before creating your own. This is part of an internal server error and you will just have to wait for a solution.
Thanks.
I’ve attempted to merge all topics about the same issue. Sorry for the mess.
It’s a system issue. There is nothing you can do right now.
www.fashionamore.in
Getting error No SSL certificate was found
Below are the steps I did.
step 1 : Update CNAME Records in Cpanel and wait for it to become active
Step 2: Requested for the SSL Certificate
Step 3: Update the Private Key and Certificate in SSL/TLS in Cpanel
when using https:// it is not working Attaching screen shots
This is part of the system issue; Please read the pinned topic.
Thank you. Is there an ETA for this Issue, This helps to plan my next steps. Thanks in advance.
If there was one, we would have given it. But usually there isn’t.
That would be quite easy to check yourself, isn’t it?
same issue last 2 day not working please help
There seams to be another SSL issue, please wait for it to be solved.
I am having same problem. I updated dns records, got my SSL cert and then install those in cname but it shows no SSL found .
Please help
Please provide a username and screenshots. Thanks.
Edit: Just saw your other topic, ignore this message and hope the issue is solved soon.
Have you tried to enter https:\ instead instead http:\??
Did you upload the key first and the certificate only when the key was already uploaded?
yes
Then you are probably experiencing this:
