No need. Use Softaculous to install to lojafortnitept.com
hmm ok in the new domain right?
Yes.
i choose the protocol:https://lojafortnitept.com(only https://)or https://www.lojafortnitept.com(with www.)?
ok thx why this appears “A trusted SSL Certificate was not found”
Nevermind.
If not possible, use http://lojafortnitept.com instead.
You can turn on “https rewrites” inside CloudFlare
i already install and now?i transfer the database sql?
can u please answer?
Preparing my reply…
ok
You need to export the following tables from the old database:-
xxxx_commentmeta (optional)
xxxx_comments (optional)
xxxx_links (optional)
xxxx_postmeta
xxxx_posts
xxxx_term_relationships
xxxx_term_taxonomy
xxxx_termmeta
xxxx_terms
where xxxx_ is your wordpress prefix
yes,the backup of the database will put the all tables
i can delete the other database right?
Only delete after successful restoration. Keep it for the time being
yes
is now importing to the new site
I already imported but nothing new appeared in the admin panel wordpress
Do not import yet.
Once ur sql files are ready, add the following lines before beginning of each table
The Wordpress prefix must match your current installation. The drop table must match the name of table being created.
i already import,u dont say this before,rip.
